Forums >> Revit Building >> Technical Support >> Elevator / Maint. Pit - Revit Architecture 9
60 Posts No Rating |
Howdy, when i create a building section, the 'Earth' poche cuts out correctly around my building put does not cut out around elevator and maintainence pits, it just goes right through these areas? I have foundation walls and floor slabs defining these areas? thanks j
Add another pad to cut your pit. Under the site tab.
yes, i tried that and have attached a dwf of the results. it does not work correctly as you will see. this seems like such a simple issue, drafting 101. i have even tried making these areas into rooms but still no luck. i have made the bottom of the pit an actual level as well, but no luck. what if this was a partial basement...would i have the same problem? thanks for your input, it got me a little closer, at least i dont have earth in my pits j
Sorry but pads do work correctly when done right. First, the pad should be defined to the outside of your pit walls - not the inside. This should take care of the line at the top of the topo. Remember - this is just like you build it. Second- the line at the top of the wall / bottom of the slab would be there in real life - unless you plan on puring the wall with the slab. But - if you want to get rid of the line, use your join geometry tool - that is assuming the pit opening in the floor actually matches your wall location. Third, I assume you will be placing another pad for your other pit? Finally - you don't need a level or rooms to make this work ... but if you want them....
The plot thickens.... it would appear that if i have multiple contour lines in my Architectural site plan, i need to merge those surfaces, which is not so good if you want to show the site grading. i did the other things you suggested and they worked great as long as i only have one topo surface? j
I'm not sure I understand. Why would you have more than one topo surface .... or do you mean you have a split surface? Did you look at graded regions on your site tab?
I was confused, just getting used to the site contour stuff. I appreciate the solution and will keep working on developing my site plan and watch how it effects my building sections j
working with Pads and toposurfaces |
Fri, Jun 8, 2007 at 3:17:50 PM
need help on elevator... |
Fri, May 25, 2018 at 4:23:18 AM
CALCULATING THE RIFLE PIT ? |
Mon, Jul 28, 2008 at 4:00:32 PM
Slab edge with different profiles |
Tue, Oct 11, 2016 at 11:23:27 AM
New Elevator Family |
Wed, Sep 13, 2017 at 6:42:19 AM
Members: | 2101437 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
