48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> title bubble tag
Sun, Mar 22, 2009 at 1:26:06 AM | title bubble tag
Lilian2009
i tried to click on it and hopefully somekind of blue grips will appear so I can adjust the length of the drawing title but there isn't any grips appear. i would think this is fairly straightforward...but i'm missing something simple.
your help is apprecaited. thanks.
IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP.
Sun, Mar 22, 2009 at 7:35:09 AM | title bubble tag
4 Stars: 203 Votes
You must select the "Viewport" like in the image then you can select the "Blue Grips" and adjust like you want....
drawing reference without callout bubble or section tag???
Thu, Jul 16, 2009 at 2:18:48 PM
bubble callout tag
Thu, Jul 17, 2008 at 3:00:42 AM
Interior Elevation Tag
Fri, Dec 4, 2009 at 11:20:56 PM
tag an imported dwg title block
Thu, May 12, 2011 at 12:34:14 PM
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:08 PM
Page generation time: 0.9610
