58 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Remove line thickness for viewing purposes?
Tue, Jun 28, 2005 at 5:39:56 PM | Remove line thickness for viewing purposes?
Robb
How can I change my settings in Revit to display my drawing as thin lines instead of showing lineweights? Sometimes i'd like to see the wall materials and with the lineweight on its hard to see.
Tue, Jun 28, 2005 at 5:55:35 PM | RE: Remove line thickness for viewing purposes?
sekta
Hi Rob, There's a toggle switch on the top toolbar about half way across. The icon looks like a row of thick lines with a diagonal slash then a row of thin lines. If you hover over the icon the tooltip "Thin Lines" is displayed. You can then view with or without lineweights as you require. Hope that makes sense!!
Tue, Jun 28, 2005 at 7:13:22 PM | RE:
Robb
Hi Rob,
Thanks so much!
Line thickness in detail family
Wed, Jul 1, 2015 at 7:09:56 AM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:35 PM
Topo Cut Line thickness
Tue, Feb 14, 2012 at 10:49:24 AM
View Title Line Thickness
Thu, Jan 24, 2008 at 1:42:39 PM
changing line thickness in composite walls
Wed, Mar 25, 2009 at 7:11:09 AM
Page generation time: 1.3874
