Forums >> Revit Building >> Technical Support >> Can't get Rooms (Room Tags) on Second Level...
What am I doing wrong? I am trying to put room tags on a second level and they are reading exterior walls for some reason. I've checked the view range and it is cutting through the walls I am trying to put room tags in. In the option bar I have the Upperlimit set at 2nd level... for the hell of it I put it on every level and none work. I dont know why I am having this problem... it has never happened before. Thanks
And in settings you have "At wall finish"?? they are "Rentable", "Gross"??? Did you try the "Room Separation" to check if solve the problem??
Edited on: Sat, Mar 21, 2009 at 7:14:11 AM
It sounds to me like the host level of the views you are trying to place the tag on is not set to Level 2?
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
thanks guys... I felt unpatient last night to troubleshoot it... so I just struck another level and it solved everything. I will keep this post in mind if it ever happens again. thanks again Edited on: Sat, Mar 21, 2009 at 11:01:12 AM
Edited on: Sat, Mar 21, 2009 at 11:01:34 AM
Pamoroso, can you please, post here how you solve the problem??? what you do step by step so in the future the others guys who follow this thread can have a change to know how to solve the same issue!!!!
typhoon... I found an alternative method to get it working. This method you will have to transfer any detail lines you have to the new plan. What I did was cut a section through my project... and created another level to replace the one that was messed up. I couldnt delete the messed up level because it has associated to floors and walls to them... So I just renamed that level in section and deleted it off my floor plans. After creating the new level... I was able to place my room tags. Its a little and busy... but its working.
Edited on: Sat, Mar 21, 2009 at 3:33:54 PM
Thanks Pamoroso.
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:52 PM
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:49 AM
Room Tags - |
Thu, Aug 30, 2018 at 11:26:11 AM
Can't create room name in revised room |
Fri, Jun 24, 2016 at 7:21:11 AM
Rooms & Room Tags |
Tue, Nov 17, 2009 at 7:14:53 AM
Members: | 2114589 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
