57 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
Fri, Mar 20, 2009 at 1:06:56 PM | Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
joeinck
This is a strange one:
I like to use the Solid fill surface pattern for exposed concrete slabs, and i set the solid fill depth to 240, 240, 240. This adds a nice light shade and helps things read better. At 1:200 the some of the Walls/doors etc.  disappear, but at 1:100 they show just fine. Is this a function of my graphics card or is something else going on?
Hats off to anyone who can figure this one out...
Fri, Mar 20, 2009 at 2:00:54 PM | Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
The fill just becomes too dense.  I would turn it off at the smaller scale settings.
Mon, Mar 30, 2009 at 2:22:10 PM | Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
joeinck
Thanks, I think that is the easiest thing to do also...
j
Showing Load Bearing Walls from a lower Floor Plan
Thu, Feb 16, 2012 at 10:02:05 PM
Solid Fill Hatching
Tue, Dec 13, 2005 at 7:11:21 PM
Revit 2009 - Fill Patterns
Sun, Nov 21, 2010 at 9:17:44 AM
Room behavior different in 2009
Thu, May 1, 2008 at 1:59:54 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:02 PM
Page generation time: 4.4382
