98 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Spot Elevation without Target
Fri, Mar 20, 2009 at 11:31:04 AM | Spot Elevation without Target
everist
3 Stars: 2 Votes
All,
Is there a way to create a spot elevation family type without the target? I am refering to the spot elevation symbol you get when you go to Drafting / Spot Elevation.
Fri, Mar 20, 2009 at 2:07:29 PM | Spot Elevation without Target
Open your spot elevation family....delete the target graphics.... give it a new name
Fri, Mar 20, 2009 at 4:33:14 PM | Spot Elevation without Target
everist
3 Stars: 2 Votes
The spot elevation family is a system family and means of opening it is not readily obvious. Any suggestions?
Fri, Mar 20, 2009 at 4:44:16 PM | Spot Elevation without Target
4 Stars: 202 Votes
You have already that kind of "Spot Elevation", with or Without "Target"...
Fri, Mar 20, 2009 at 4:57:56 PM | Spot Elevation without Target
everist
3 Stars: 2 Votes
Thanks all... Some simple family types have gone by the way of successive purges. I knew it was a simple thing. Under the type properties of the Spot Elevation / Graphics / Symbol / none. I appreciate the help!
Target size of Spot Elevation (Revit Architecture 2008)
Wed, Aug 6, 2008 at 9:43:57 AM
Spot elevation target symbol
Wed, May 27, 2015 at 5:09:18 PM
Target size of Spot Elevation (Revit Architecture 2008) 2
Thu, Dec 18, 2008 at 11:21:26 AM
elevation target arrow head
Thu, Apr 3, 2014 at 1:21:55 PM
Spot Elevation Forced Text
Fri, Apr 22, 2011 at 1:04:01 PM
Page generation time: 1.2578
