Forums >> Revit Building >> Technical Support >> Floor Demo
5 Posts No Rating |
I have a floor that has to be partially demolished. The only solution I can come up with is to trim the existing floor back to the line of demolition and then draw in a new floor section and then pick Demolish. Even this does not work well because, a floor in plan doesn’t appear all that differently in demo as it does in existing conditions…there is no dashed perimeter line or half-toned surface material. Plus this seems like an extreme procedure…to cut out a section of a floor only to replace it with a new section in order to demolish it. Also, if the trim line moves, I would then have to move the floor line for both surfaces. Is there a way to create a sub-region where the trim line travels between the existing and demo floor sections?
Draw a grid line where they meet. Align and lock both floors to the gridline. When you move the grid line, the join will move with it. With regard to the display, you should be able to get it to display the way you want. Look at 'Graphic overrides' in the Phasing dialogue box.
5 Posts No Rating |
Thanks tim123, I will give that a try. By grid lines, do you mean column grid lines? Or just model lines? I have tried changing overrides for the demo phase but when I get to Projection/Surface Patterns, the only options I have are cross-hatch / endgrain type patterns. The floor I am demolishing is a carpeted wood truss floor. There isno pattern equivalent for that and even when I use half-toning, the carpet 'fibers' are so small that it isn't even distinguishable from existing carpet. The perimeter line comes in dashed all right but it obscured by the perimeter of the existing floor. It just seems logical that Revit should have some kind of shared exist/demo line that will display dashed and also move with the shared edges on surface type demolitions.
Room/area tags on floor plan with demo'd wall |
Tue, Feb 10, 2009 at 9:53:42 AM
stairs wont demo off my plan |
Wed, Aug 13, 2014 at 3:16:06 PM
How Do I Create Existing and Demo Floor Plans From Linked Model |
Thu, Dec 20, 2012 at 9:20:07 AM
exporting demo layers |
Sat, Apr 21, 2012 at 8:15:27 AM
Existing floor with a new stair opening... need help with phasing |
Thu, Apr 25, 2013 at 11:10:35 AM
Members: | 2115355 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
