42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Exporting 3d cad formats with links
26 Posts No Rating |
I'm working on a big model (50 story residential tower) and have broken individual "typical floorplates" into seperate revit models which are linked into the central model with the tower structure, etc... to make working on the floorplates manageable (The units include 3d furniture for 3d representation purposes) The whole system is working great EXCEPT when I try to export the model to 3d cad (for use with sketchup) it exports each link as a seperate cad file, rather than exporting them all together!! Is there a way to fix this besides binding all of the links? (I tried that and Revit Crashed) I'm using revit 2009 with 3GB available ram and a Pentium 4 3.4 GHz CPU
Solution: Uncheck "xref views on sheets" when exporting the 3d view. Revit will then export all visible geometry into one 3d cad file (including all the links)
Imported layers still active when exporting |
Fri, Feb 26, 2010 at 8:44:40 AM
Maintaining 0,0 when exporting a DWG (REVIT 2009) |
Fri, Sep 25, 2009 at 11:58:43 AM
Exporting to CAD from Revit 2012 |
Mon, Oct 8, 2012 at 7:30:49 AM
Cad links |
Sun, Jan 6, 2008 at 2:59:15 PM
Can I set CAD links to default to the foreground? |
Thu, Jun 23, 2016 at 4:58:31 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
