19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Moving whole building
Fri, Mar 20, 2009 at 7:51:38 AM | Moving whole building
simondt
I have a need to move a finished building model around its site due to client changes and other stuff but everytime i select the ground floor to move it i get hit with loads of error warnings about geometry becoming disjoined and rooms merging into each other.  Its a single storey building but i have levels for the flat and pitched roofs aswell.
I've tried grouping the whole building but the same problems occur. anyone got any thoughts as this really would be a nightmare if i have to rebuild the model.
thanks
simon
Fri, Mar 20, 2009 at 7:57:34 AM | Moving whole building
tim123
4 Stars: 19 Votes
Can you not move the site instead?
Fri, Mar 20, 2009 at 8:12:21 AM | Moving whole building
simondt
If i move the site then all the gps data information goes for a tumble
Fri, Mar 20, 2009 at 8:22:03 AM | Moving whole building
tim123
4 Stars: 19 Votes
You can move the site beneath the building and then relocate the project to the correct position again using the 'Relocate this project function'.
Fri, Mar 20, 2009 at 8:26:58 AM | Moving whole building
gnomey
you can also set the building up as a separate linked revit file.  then you can move it without problem.
Fri, Mar 20, 2009 at 9:33:40 AM | Moving whole building
simondt
thanks
i'll give both these options a go and see what happens
Fri, Mar 20, 2009 at 9:54:24 AM | Moving whole building
I really like keeping my site in a seperate model.  Then if I want to add plantings and entourage for rendering, it does not take up working memory space because I will only load the link when I need to.  Be careful with this approach because linked models will not tag or keynote in the main model.
Wed, Aug 31, 2016 at 3:32:56 PM | Moving whole building
NobleLP
Interesting, I made a file with all the objects, groups, grids, and levels.
Deleted the same except levels and purged the file of groups.
Linked the saved file origin to origin and moved the link to the corrected location (a small rotation less that 1 deg. and a small xy move to place it in relation to known property lines.
I pined the link and have dimensions locating grids. During the bind Revit deleted the dimensions and proceeded with the bind, I did not include the levels which worked as expected, in the end the link moved to the original position negating the process.
I gave up and we are living with the rotation discrepancy.
Any thoughts why this didn’t work?
Thu, Sep 1, 2016 at 6:50:47 AM | Moving whole building
You have not told in what context this file is used.  Is it linked into anothr file and that needs to be rotated? There is a far easier process than what you used.   Watch this video.
http://www.youtube.com/watch?v=BigvY4LT-RI
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:56 AM
Moving Building up with out moving the site
Sun, Jul 31, 2016 at 5:20:11 PM
Rotating property line and site without moving building...
Sat, Jun 15, 2013 at 10:31:21 AM
Changing level height values while keeping building in place? [ 1 2 ]
Mon, Apr 13, 2015 at 1:47:49 AM
18
Moving a Building
Wed, Apr 30, 2008 at 5:50:00 AM
Page generation time: 1.6170
