34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Matrix Schedules?
Thu, Mar 19, 2009 at 5:12:41 PM | Matrix Schedules?
atkinsonhall
(Revit Arch 2009)
Any way to make a matrix-style room finish schedule?
Thanks,
Fri, Mar 20, 2009 at 8:03:10 AM | Matrix Schedules?
tim123
4 Stars: 19 Votes
Can you be more specific about what you want?
Fri, Mar 20, 2009 at 8:26:50 AM | Matrix Schedules?
atkinsonhall
ok, i'll try.
for a room finish schedule, i would like to show the room name and numbers going down on the left side, while the finish materials (VCT, Carpet, Gyp Bd, Acoustic Tile, ect) going across the top. At the intersection of the material and a room name would be a check/circle/x...or some kind of mark to show that that room recieves that material....a matrix schedule.  see attachment.
Fri, Mar 20, 2009 at 8:41:13 AM | Matrix Schedules?
3.5 Stars: 401 Votes
You can do this if you have a shared parameter for each finish type in each room.  In other words ... about 22 parameters.  Even then, you will not be able to have the bullets (maybe you could if they are in your font and the parameter is text???)
Fri, Mar 20, 2009 at 8:58:56 AM | Matrix Schedules?
atkinsonhall
maybe with the parameter as a "yes/no".....?
Fri, Mar 20, 2009 at 2:57:09 PM | Matrix Schedules?
davbrink
4 Stars: 1 Votes
The problem with the yes/no is that you either get the words "YES" or "NO". It is not like you can get a YES and a blank.  You can not change the font for those fields only. (If I am wrong please tell me I would love to know) What we have done is create a parameter that is next and just mark it with "X".
Mon, Mar 23, 2009 at 9:06:40 AM | Matrix Schedules?
davbrink - you are right - that's why we use a text field and not a y/n.
Mon, Mar 23, 2009 at 9:45:21 AM | Matrix Schedules?
atkinsonhall
i still havnt figured this out yet. do any of you have a schedule or at least a small example of what you are talking about?
Mon, Mar 23, 2009 at 10:39:38 AM | Matrix Schedules?
Just create your room schedule and add a parameter for each finish column you want.  It does not have to be shared if you are not going to export the schedule.  Make each parameter an instance type - text.  You can then group your column headers together to get the floor/base/walls/... groupings.  Look in you help to learn how to do this.
Mon, Mar 23, 2009 at 11:09:31 AM | Matrix Schedules?
atkinsonhall
thanks. i got it to work. i made a group with "VCT", "Carpet", and "Ceramic Tile" and grouped them with the header "Floor Finish"......however, i changed the orientation for the various finished to be vertical...but they still show as horizontal. any ideas?
Mon, Mar 23, 2009 at 11:33:19 AM | Matrix Schedules?
#11
atkinsonhall
i got it.
they show up vertical once placed on a sheet. thanks for the help.
Matrix transforms
Tue, Jun 22, 2010 at 3:07:42 PM
Chicago Code Matrix
Mon, Aug 8, 2011 at 12:42:21 PM
Unlinked Code Matrix in Revit 2010?
Thu, May 13, 2010 at 2:12:40 PM
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Page generation time: 0.2479
