70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Where is my underlay?
Thu, Mar 19, 2009 at 1:44:11 PM | Where is my underlay?
NancyHKA
I'm trying to underlay a roof plan onto a lower level plan, so I can trace the roof with the pen tool so it shows up as dashed lines in the view.  I can see the roof in "level 8", but when I underlay that level into the view, nothing shows up.  Why isn't the underlay working?  I've found lots of threads about this problem, but no one seems to have found a satisfactory answer.  Adjusting the view range does not help.  What can I do?
Thu, Mar 19, 2009 at 2:13:25 PM | Where is my underlay?
4 Stars: 201 Votes
in the view you want to "trace the roof with the pen tool" write VP then you can see the "Underlay"....
Fri, Mar 20, 2009 at 9:07:22 AM | Where is my underlay?
NancyHKA
yes.  I understand how the underlay function works.  When I assign the underlay, nothing shows up.
Fri, Mar 20, 2009 at 9:14:50 AM | Where is my underlay?
4 Stars: 201 Votes
And are you assign the "underlay" to the Level where is the roof created???
Fri, Mar 20, 2009 at 9:19:16 AM | Where is my underlay?
NancyHKA
I'm assigning the underlay to a level where the roof is currently visible.  But when I do this, not only do I not see the roof, but I don't see any underlay at all.
Fri, Mar 20, 2009 at 9:25:15 AM | Where is my underlay?
4 Stars: 201 Votes
Can you put a screenshot with you monitor (where i can see the project browser)  and The VP box active (where i can see the Underlay parameter)???
Fri, Mar 20, 2009 at 10:11:09 AM | Where is my underlay?
NancyHKA
I think I figured this out (sort of).  The clerestory plan that I'm trying to underlay something into is associated with Level 2.  The only level I seem to be able to successfully underlay into it is Level 3 (the level right above it).  So I got the underlay to work, for my purposes, but it still seems strange - I seem to remember having more flexibility with the underlay in past projects.
Fri, Mar 20, 2009 at 10:32:28 AM | Where is my underlay?
4 Stars: 201 Votes
If you have your roof in Level 3 and you want to "trace the roof with the pen tool" in Level 2 then in the level 2 put the underlay to Level 3 and it work...
Fri, Mar 20, 2009 at 10:37:33 AM | Where is my underlay?
NancyHKA
Yes, that is what I just did.  But I have some roofs that don't show up in the Level 3 underlay, and for some reason underlaying any level higher than Level 3 just doesn't work.  Anybody else have any ideas?
Fri, Mar 20, 2009 at 11:43:15 AM | Where is my underlay?
tim123
4 Stars: 19 Votes
The underlay only shows what is on that level, regardless of the bottom or view depth.  You can show stuff above the level that you are trying to draw on by temporarily raising the top and cut plane above the roofs that you are trying to draw.  Alternatively, draw reference planes on the roof edges, which will be visible on the plan that you are trying to draw on.
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
wrong underlay showing
Mon, Jan 27, 2014 at 1:29:57 PM
Page generation time: 0.9040
