65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Double footing problem - plz help??
Wed, Mar 18, 2009 at 5:03:37 PM | Double footing problem - plz help??
MatthewLynch01
Hi
When I attach a bearing footing to my wall with the base extension of the inside layers at slab level and the rest of the wall at T.O footing level, 2 footings appear - 1 at the extension layer and one at the bottom of the wall where I need it to be. How do I get rid of the second footing?
Thanks
Thu, Nov 15, 2012 at 3:18:18 PM | Double footing problem - plz help??
ashevilleARCH
I have just come across this problem too.  Does anyone know a solution?  Adding finish layers to walls is great...until now.  Obvisouly I don't want my gwb to extend down to footing.
Revit Architecture 2011
Thu, Nov 15, 2012 at 3:24:51 PM | Double footing problem - plz help??
I split the wall horizontally at the floor line and use a foundation wall which doesn't have the interior finishes.
Double Footing
Fri, Mar 13, 2015 at 9:51:12 AM
Strange problem !!! hlp plz
Thu, May 29, 2008 at 4:14:43 PM
13
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:58:51 PM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:48 PM
13
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:14 PM
Page generation time: 0.6556
