111 Users Online (110 Members):
Forums >> Revit Structure >> Technical Support >> Beam Systems - Girder as default?
20 Posts No Rating |
When creating beam systems Revit always defaults the beams created as joists. Is there a way so that it will default the created beams to girders instead?
10 Posts No Rating |
If, for instance, you always want a particular type of beam to show as a girder (like all of your wide-flange steel beams) I'd edit the family by adding a symbolic line of the type "Stick Symbols (Projection)". Also, change the parameter "Symbolic Representation" to "From Project Settings" under the Category and Parameters menu. In the beam family change the object style for structural framing to the line type and weight you want and it will always show up that way in your drawings. You have to do this in every beam family that you want to force to the girder line style. Hope that helps.
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Beam Systems |
Wed, Aug 13, 2008 at 11:42:00 AM
Sloped Beam Systems Q's |
Mon, Nov 14, 2016 at 11:48:46 AM
Modifying Existing Family |
Thu, Nov 25, 2010 at 12:29:15 PM
Beam Systems |
Wed, Feb 8, 2006 at 2:00:42 AM
Members: | 2042307 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
