131 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Merging Spaces?
Wed, Mar 18, 2009 at 11:01:05 AM | Merging Spaces?
heinzk1
I have a room that is L shaped and for some reason when I create a space for the rooom it wants to make 2 separate spaces for that room.  Is there a way to combine or merge spaces into 1?
Just wondering,Ken@rlmrlm.com
Wed, Mar 18, 2009 at 11:21:33 AM | Merging Spaces?
If there are two spaces then you have placed something that tells Revit you have two spaces.  Revit defines spaces from room bounding elements.  The most common are walls set to be room bounding and room seperation lines.  You must have one or the other between these two spaces.  If it is a wall (maybe a low wall), turn off room bounding in its properties.  Otherwise, make sure VG shows room boundries and look for one of those between your areas.
Tue, Feb 2, 2010 at 10:34:05 AM | Merging Spaces?
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
check for room separation lines in your link and your MEP model through VG (its a sub catagory of lines) making both space and room separation lines another color, and a wider line helps a lot.
Edited on: Tue, Feb 2, 2010 at 10:41:19 AM
Wed, Jun 23, 2010 at 4:49:07 AM | Merging Spaces?
Corleone07
I have Two room divided by wall with huge opening.
Revit interprate its as two rooms. But i want listet its as one room.
Is it possible to merge two spaces?? - that is the question Winking
Wed, Jun 23, 2010 at 7:11:54 AM | Merging Spaces?
gebber
gebber Avatar
5 Stars: 4 Votes
As WWHub says, select the wall with the opening and in its properties uncheck roombounding.
Be aware, when this wall is goin up to a higher level you'll ger the warning room is not in a enclosed area, you'll make this area enclosed with a room separation line.
Wed, Jul 14, 2010 at 12:45:17 AM | Merging Spaces?
AmandaBob
I'm coming! Let's see what happens
_________________________________________
 uggs
ugg boots
Fri, Feb 10, 2012 at 2:56:17 PM | Merging Spaces?
bigevent
Awesome.. Thanks for the room bounding check off tip.
Revit Spaces Elec VS Mech
Tue, Feb 2, 2010 at 10:50:51 AM
Merging Shared Parameters
Mon, Jun 8, 2009 at 3:08:13 PM
Merging Toposurfaces
Tue, Apr 21, 2015 at 8:07:54 AM
Beam not merging
Mon, Mar 16, 2009 at 5:57:10 AM
dimension text format, remove extra spaces
Tue, Aug 24, 2004 at 8:38:43 PM
Page generation time: 0.2698
