138 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rendering joists
Mon, Jun 27, 2005 at 12:14:27 PM | rendering joists
khillman
Hi, I have a series of DLH-Series Bar joists (from the Revit imperial library) in my revit model. In elevation, the lines of the bar joist are not seen, only the horizontal lines of the top and bottom beam of the joist (no webbing). In a 3d view, when rendered, this also occurs, so I only see the horizontal bars, not the webbing, so it looks like the joist is just two pieces of unconnected metal bars floating in space. Please help me fix this. Thanks. -Chris
Mon, Jun 27, 2005 at 1:53:48 PM | RE: rendering joists
TomDorner
4.5 Stars: 25 Votes
You will have to open the family for editing and modify the visability parameters so that the elements you want to see in certain types of plans are visable. I opened the family and the first thing I noticed is that there is another family nested into it for the webs: angled web-family.rfa Open this family and check the options you want for its visability, pay attention to level of detail as well. Load this back into the DLH bar joist family. In the main DLH bar joist family make sure the other elements you want to see have their visability set for the right type of view and view detail level. HTH Tom Post edited on 2005-06-27 13:54:55
Mon, Jun 27, 2005 at 2:07:05 PM | RE: rendering joists
khillman
thanks Tom, that worked. I forgot to modify the visibility of the nested family when I oped it for editing, that was my problem. Thanks for the help. -Chris
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:16 AM
joists
Thu, Oct 11, 2007 at 4:43:15 PM
JOISTS ON BEAM DISPLAY REPRESENTATION
Fri, Dec 19, 2008 at 10:38:04 AM
Sloping Bar Joists?
Thu, May 7, 2009 at 9:41:09 AM
Adding roof bar joists on different hight brg. ends..
Fri, Oct 9, 2009 at 12:02:51 PM
Page generation time: 1.9765
