64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Help opening older version of Revit file
Hi, I've tried serching for this in the forum but I only kept on coming across people trying to open newer files on older versions. BUT in my case I want to open an older version (I have no clue in what version it was created) and I have tried it on Revit 9.1, and 2009, but can't get it to open. Shouldn't it be like word if you have 07 you can open 97-03 but if you have 97-03 you can't open 07???? I would really appreciate it since this projects bids in a couple of days and need it to help my estimator for his take off... thanks, -cadviz
If plans & specs don't match, it equals a shitty project. CADVIZ |
I assume you are getting errors such as "your project needs to be manually upgraded"? How large is the file? If its small, then as the error message suggests file a Support Request with Autodesk and they should be able to update it fairly quickly for you. If its quite large you might just need a computer with sufficient RAM to be able to upgrade it as upgrading is very RAM intensive. A 100MB file can typically require 2-4GB RAM to update... HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Mr Spot, thanks for the support... you can dis-regard my question, i just figured it out.... thank you very much! -cadviz
" Mr Spot, thanks for the support... you can dis-regard my question, i just figured it out.... thank you very much! -cadviz " if you think that what you found out is something that other users may benefit from, could you please post the soluition.
it was just a dumb question on my behalf... turns out it was a newer version[[I was thinking I was sitting in the computer running 09 where I would be up tp date with no issues) I was actually trying to open it in 2008 and 9.1 then I realized HEY! let me try it on the other computer (which runs Revit Architecture 2009) and it worked so we're gonna have to update real soon to avoid any issues down the road.
Opening File |
Mon, Apr 24, 2006 at 9:21:33 PM
Saving |
Sat, Jan 20, 2007 at 11:55:53 AM
Are people still using older versions of Revit? |
Sat, Aug 29, 2015 at 12:49:17 AM
Origin of the word Revit? And how do "save as" to older version of Revit? |
Thu, Sep 11, 2014 at 2:20:30 AM
Going from a Revit 2012 file to an older version of Revit |
Thu, May 26, 2011 at 11:58:53 AM
Members: | 2042216 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
