107 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> missing legend components
I am trying to create a legend, but none of the in-place families that I created using the "create" button on the modelling tab shows up in the list of available families when I click "legend component". Imported families work fine. In fact, if I start a new family outside of the project, copy the in-place family to that new family, and import the new family into the project, it shows up fine in the legend components list. Do I need to create families outside of my project in order for them to show up as legend components, or is this problem due to a program bug or a setting I have incorrect?
In-place families should be used sparingly to say the least. They are for one off pieces that for whatever reason are difficult to model outside of the model. If you are needing to show legend components of them then there is a good chance you've repeated them around your model and as such should be modelled as normal families. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
VIEWING LEGEND COMPONENTS PROPERLY |
Tue, Apr 14, 2009 at 10:04:02 AM
Legend Components |
Thu, Aug 12, 2010 at 2:00:15 PM
Curtain Wall Door as Legend Components |
Mon, May 19, 2014 at 7:55:50 PM
Elevation tag missing in Symbol Legend |
Tue, Nov 21, 2006 at 1:18:43 PM
best practices for wall type sheet |
Tue, Dec 8, 2009 at 9:44:48 PM
Members: | 2042307 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
