54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do I get a slab system family into my project?
Tue, Mar 17, 2009 at 11:37:51 AM | How do I get a slab system family into my project?
grebiwnotnerb
3.5 Stars: 11 Votes
I am using revit architecture 2009.
 I'm trying to make a floor slab but when I select slab in the structural menu it creates a floor, so I go to change it in the dialogue box and it doesnot have a slab catagory.  How do I load a Slab system family into the project so that I can create an actual floor slab?  I've always wondered what would happen if I were to delete say, all the stacked walls  in a project, would that get rid of the stacked wall system family in the walls dialogue box? How would I get it back to make stacked walls?  I'm sure I'm just overlooking something simple, but what?
Tue, Mar 17, 2009 at 11:45:53 AM | How do I get a slab system family into my project?
grebiwnotnerb
3.5 Stars: 11 Votes
Maybe there isn't a slab system family.  I just want to be able to create a slab with metal decking in it and I looked it up in revit help and it says you need to change it from a floor to a slab.  I've seen other posts where people have successfully modeled a slab with decking beneath.  We are sick of detailing in decking and so if it can be modeled that's terrific.  But how do you do it.  I've poured over many posts and can't find one that explains how it's done, it's mostly just people haveing problems with a profile not loading, I can't even get that far.  What am i doing wrong?
Tue, Mar 17, 2009 at 12:52:42 PM | How do I get a slab system family into my project?
3.5 Stars: 395 Votes
You can only assign a thickness and a material to a slab and call it decking but it will not be a model element.  You still have to add the profile when you cut the slb across the deck webs.  BUT - use repeating detail to show this in detail views.
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
Thickened slab edge
Sat, Jan 28, 2012 at 4:57:49 AM
Floor Slab Slope
Tue, Jan 30, 2007 at 11:01:08 AM
Shared Parameters as part of a Foundation Slab
Tue, Jun 7, 2011 at 5:37:47 AM
Editing System Families
Sat, Dec 5, 2009 at 3:53:10 PM
Page generation time: 1.4147
