68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> System Wall Properties
Tue, Mar 17, 2009 at 1:15:02 AM | System Wall Properties
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
when i place a system wall and pick "Basic Wall : Exterior - Brick
and CMU on MTl. Stud" and then look at its element properties-
and type properties and edit assembly- nowhere do i see the cap
on the wall or the sweeps or the lower stacked bricks..
where is all that stuff?  RAC 2009
Tue, Mar 17, 2009 at 7:41:34 AM | System Wall Properties
You have something wrong here.  A basic wall does not have sweeps as originally defined.  You can add them if you want to.  A basic wall is not a stacked wall.  Stacked walls are made up of at least two basic walls.
When you edit the wall structure, you assign materials to the wall components and you can use the preview to look at the wall in plan or section.  The bottom bortion of the edit GUI is where you can assign sweeps and split or modify regions.
You need to spend some time in your H E L P
Tue, Mar 17, 2009 at 6:51:32 PM | System Wall Properties
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
 "A basic wall does not have sweeps"
start a new project and hit the wall tool and
in the wall types drop down select  "Basic Wall : Exterior- Brick and CMU on MTl. Stud"
and you might see those things already on the wall with your very own eyes..
let me know what you see..
Tue, Mar 17, 2009 at 7:51:09 PM | System Wall Properties
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Go to the wall properties,
Turn on the Preview, then switch the preview to section mode.  There you can see how the compound wall is setup.
Regards,
Chris.
Wed, Mar 18, 2009 at 12:55:04 AM | System Wall Properties
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks spot- i missed the section view in the preview..
now i see all that stuff added to the wall..
Custom Wall
Mon, Mar 16, 2009 at 1:43:19 PM
Creating curtain wall system on an angled wall
Fri, Dec 16, 2011 at 4:01:22 AM
Timber curtain wall system
Wed, May 8, 2013 at 7:40:34 AM
"inherit properties" when starting a wall
Wed, Jan 19, 2005 at 4:36:36 AM
Editing System Families
Sat, Dec 5, 2009 at 3:53:10 PM
Page generation time: 1.9430
