56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> how are joined beams and floors in 3d view?
3 Posts No Rating |
I created floors, beames and colomuns there isn't a problem in plan view.But in the 3d view I don't wan't to see joined lives.
There are visible edge between beams and floors. The join geometry command isn't cleaned these in the 3d view.
Please help me.
2 Posts No Rating |
use the linework tool
3 Posts No Rating |
Is there a different solution of this problem ?
In most cases providing the materials are the same you shouldn't see any join line... If the materials aren't the same, unjoin, then swap material and rejoin.
3 Posts No Rating |
Thank you very much.
Joining beams to walls and floors |
Thu, Jan 15, 2009 at 9:00:36 AM
How to see the upper floor (beams,floors) in plan view? |
Tue, Jun 14, 2005 at 4:37:20 AM
Tagging for floors between beams |
Tue, Jan 31, 2012 at 5:23:10 PM
Auto Join Concrete Column & Beams |
Thu, Jul 1, 2010 at 2:08:30 AM
Beams connections - "soft", not sharp |
Fri, Dec 7, 2012 at 9:06:42 AM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
