44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View controls in Sheet window
Sun, Jun 26, 2005 at 4:28:17 PM | View controls in Sheet window
Phrederick57
I am having a hard time understanding how to control the view in the sheet. I can not seem to figure out how to rotate a plan view without moving the drawing title with the view. Can anyone give me some guidance here. As well how does one control the view window size? can it be changed in the sheet view? Frederick
Sun, Jun 26, 2005 at 5:59:52 PM | RE: View controls in Sheet window
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When your in the sheet view. Activate the view you wish to rotate, select the crop region and rotate as required. Whether this works will depend on what build and version of revit you are using. Current build will allow the view to be rotated without the title coming with it.
view window size
Thu, Jan 8, 2015 at 10:38:12 AM
Flip Controls
Mon, Oct 20, 2008 at 10:43:50 AM
building controls
Wed, Feb 3, 2010 at 8:26:27 AM
Copying Sections to a revision sheet
Fri, Jun 6, 2008 at 9:32:48 AM
multiple instances of the same view in sheet not supported
Tue, Dec 4, 2012 at 12:40:35 PM
Page generation time: 1.1256
