Forums >> Revit Building >> Technical Support >> Excel to comma delimited txt file
I have an window catalog with all the Andersen Tilt Wash windows that i modified and now is saved as an .xls file. It appears Revit needs to read the file with comma delimited. How do I convert the xls file to comma delimited .txt file. I tried save as with the different .txt files to no avail. Revit would not open the catalog. John
1 Posts No Rating |
The txt file and your Revit file needs to have the same name, and be in the same folder
Got that. But when i save as a .txt file, Revit won't open the catalog. It gives me an error: Row 1: unacceptable list separater y (with stupid double dots above), Acceptable list separaters are ,;:| What i need is a way to convert the .xls file to a file that revit will read as a catalog. I started typing in the new catalog in word pad and can get that to work, but it's easier to edit in excel. Unless I'm doing something wrong i can't save as from excel to a file type Revit will read.
Did you try saving it from excel as a CSV file (don't keep any fexcel formatting) then renaming the extension to txt.... that looks right to me.
WWHub, You the man. I did try the .csv file but i didn't think to reaname it to .txt (Not sure why, i renamed everything else) Anyways, worked like a charm. Andersen double hung full catalog for single wide units coming soon. Thanks, John
Family Creation Look-up table interactivity |
Thu, Jul 24, 2014 at 7:38:37 AM
Changing of unit seperation symbol from comma to point |
Mon, Jan 11, 2010 at 7:25:22 AM
Exporting schedules to Excel with multiple lines in a cell |
Thu, Jan 24, 2013 at 9:55:29 AM
Exporting Schedules into excel format |
Fri, Mar 13, 2015 at 5:53:44 AM
Custom Keynotes |
Tue, Mar 5, 2013 at 8:36:19 AM
Members: | 2114549 | Objects: | 23192 | Forum Posts: | 152318 | Job Listings: | 3 |
