55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> column and beam not joining with wall
Sun, Mar 15, 2009 at 5:18:38 AM | column and beam not joining with wall
push84
hi all, i am using revit 09,                            When i placed column in my revit its not joining/cut the wall! Can any one please help to resolve this issue?Thanks in advance
push
Sun, Mar 15, 2009 at 7:33:45 AM | column and beam not joining with wall
tim123
4 Stars: 19 Votes
If you use the architectural rather than the structural column it should clean up with the wall.
Mon, Mar 16, 2009 at 6:50:14 AM | column and beam not joining with wall
push84
Actually i copied structural column from old project and its working fine (i can do join geometry with walls) but some how my beams not doing the same....................its troubling me lot
Edited on: Mon, Mar 16, 2009 at 6:50:53 AM
Mon, Mar 16, 2009 at 6:56:16 AM | column and beam not joining with wall
push84
here is the default revit 2009 structural column..................may some experts can tell why this column not merging with walls???
Mon, Mar 16, 2009 at 6:58:00 AM | column and beam not joining with wall
push84
here is the beam which is not merging with walls and slabs..................what should i do to merge this one??? this beam was perfectly working one year before in revit 2008!!!
Edited on: Mon, Mar 16, 2009 at 7:01:21 AM
Wed, Mar 18, 2009 at 1:02:52 AM | column and beam not joining with wall
push84
hi all, its strange i just went to the family editor and reloaded my beam thats it ......its merging with walls now.....so problem solved
if any one has the same problem here is the beam for u
thank u
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
Wall to be automatically stop below concrete beam
Wed, Dec 2, 2015 at 8:58:50 AM
Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 4:40:24 AM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
Tee beam as column?
Tue, Nov 6, 2012 at 2:41:46 PM
Page generation time: 1.0985
