62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Spot Elevation for joist bearing
Wed, Mar 11, 2009 at 2:28:13 PM | Spot Elevation for joist bearing
JBrower
I have a joist bearing into a wall. When I do a spot elevation on plan it gives me the top of joist elevation. I need it to give me the joist bearing elevation instead. Can anyone help please?
Wed, Mar 11, 2009 at 3:09:48 PM | Spot Elevation for joist bearing
emgeeo
3.5 Stars: 7 Votes
It's very difficult to see what you are describing with the attached image.  Can you give/show more info.  What type of structure is this- wood or steel joist?
Are you tagging the bottom of the beam/joist seat or the top.
Spot elevation symbol [ 1 2 ]
Mon, Dec 1, 2008 at 10:10:59 AM
16
Extended 2 1/2" joist end with a 5"+ seat bearing?
Thu, Sep 29, 2011 at 3:07:20 PM
DLH joist bottom chord bearing
Thu, Dec 9, 2010 at 8:40:09 PM
Joist with bearing embeds
Mon, Mar 20, 2017 at 8:42:47 AM
double pitched top chord joist seats
Tue, Feb 15, 2011 at 3:37:51 PM
Page generation time: 1.8385
