70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> I need help with electrical design adding mechanical to it.
Wed, Mar 11, 2009 at 11:08:51 AM | I need help with electrical design adding mechanical to it.
Sawin
I need to add mechanical units to my electrical design. How do I do that? I can not find a mechaincal rooftop unit that is 240 volt single phase. aslo because this job is existing there is some exisitng equipment there and I dont know how to add them to the panel schedule. I am told I have to put in a device even though it is existing, but what about things that are in the panels that I dont show on the plans for example exterior lighting that is existing and I am only showing the new loads that are in the building. As my first project in Revit I am finding out that it is really for new consrtuction. If some one has any advice for me please respond to my post.
 Thanks
Mitchell
Wed, May 6, 2009 at 12:01:53 PM | I need help with electrical design adding mechanical to it.
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
you can accomplish this by using j boxes that are set to the existing phase and filter them out so that you dont see them on plan, good luck trying to use revits panel schedules though. ive gone back to using cad for them.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Mechanical Equipment with Electrical connections showing 0V
Mon, Oct 11, 2010 at 8:13:43 PM
Electrical in the browser
Wed, Jan 23, 2013 at 12:20:58 PM
KEYNOTING LINKS (structural, mechanical, electrical)
Fri, Nov 13, 2009 at 12:10:04 PM
AS/NZS Electrical and Mechanical Standards... Revit MEP
Tue, Aug 28, 2007 at 8:02:05 AM
Independent Freelance Drafting & Design
Sun, Jul 29, 2012 at 9:45:47 PM
Page generation time: 1.3693
