37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Tagging Curtain Walls with a window Tag?
21 Posts No Rating |
How do you tap a curtain wall? I need to schedule it on my window schedule, but I can't tag it with a window tag. Do I need to create a window tag for a curtain wall from the wall tags? can someone please help with this issue? Thank you,
We created a wall tag that looks the sme as the window tag and use that. We then schedule the curtain walls seperately - filtered wall schedule... you can make it look like your window schedule and place the schedules one on-top of the other if you want.
You can create curtain wall tags to look like your window tags and number then accordingly. You will have to create two different schedules, but you can place them on one sheet so that they look like one schedule
Thank you, both... that is very helpful....
Curtain Walls vs Window Families |
Tue, Sep 13, 2016 at 7:14:41 AM
Select all by type |
Thu, Dec 23, 2010 at 7:22:25 AM
Default Category Tag Question |
Mon, Aug 17, 2015 at 11:15:22 AM
Curtain Wall/Screen tag and schedule |
Tue, Dec 30, 2008 at 4:00:48 PM
tagging a curtain wall |
Tue, Nov 9, 2010 at 2:10:00 PM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
