38 Users Online (36 Members):
Forums >> Revit Systems >> Technical Support >> Insulation and Lining thickness for ductwork issue
Is there a way in MEP2009 to draw the ductwork already lined or insluated? It seems difficult to do after the design is complete. When I select the whole system, it wont give me the option to modify the element properties. I can select the ductwork only, but then it doesnt do the fittings. I can do the fittings seperately, but that is time consuming as it wont do fittings of different types at the same time. I would think there is a way to draw the ductwork with the insulation or lining specified, I just dont know where. I would also think there is a way to easily modify the whole system to be lined or insulated. Am I thinking to much, or is Autodesk not thinking enough?
ADSK may not be thinking this one trough yet, you have to go back after the fact its the same with piping.
http://familyjewels.typepad.com/ |
Cant find ductwork lining settings and fitting settings. |
Tue, Apr 7, 2009 at 10:44:56 AM
Duct Tags |
Thu, Jul 31, 2014 at 3:43:41 PM
Door Lining Depth |
Thu, May 3, 2007 at 2:39:56 AM
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Plumbing insulation |
Thu, Feb 20, 2014 at 8:19:48 AM
Members: | 2037296 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
