62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Schedule Calculating Field
10 Posts No Rating |
I am trying to add a field to a schedule to calculate a total but cannot figure out how to do it. I have a family of shelf units. Each unit has a length and a number of vertical shelves in each unit. Using the field "Count" I can get the total number of shelf units. I tried to create a calculate field that gives me the total length of shelving like this "Count" * "Shelf Length" * "# of Shelves" but it says I cannot use "Count" in a formula. So how do I do this Assuming I can get this working. Can I get total formatted in total inches not feet and inches.
You can create a total length without a calculated parameter - just get the total from the schedule.
I do not follow your answer. In my case I have a series of library shelving that are different lengths and they have different number of shelves high in each shelf unit. To get total length of shelving I must be able to multiply # of shelf types * their length * # of shelves high in each unit. ie If I have 6 shelves 3ft long with 7 shelves in the unit I have 6x3x7 = 126 lf x 12 inches per ft = 1512 lineal inches of shelving . Lineal Inches of shelving is waht the bldg program is written with.
Yeah sorry, I missread your query. The way to do it is to create a shared parameter in your family, called 'shelf length' or similar and give it a calculated field such as ' length x number'. Your family will then come into a project with the total amount of shelf calculated. In your schedule create the same shared parameter and you can then total these values in the schedule.
Calculating two Formulas on the same row in a Schedule |
Fri, Dec 17, 2010 at 7:22:56 AM
Calculating occupant loads using room schedule |
Wed, Mar 7, 2007 at 4:45:12 AM
Ceiling Height, Formula Field in Schedule???Possible or not??? |
Tue, Nov 3, 2009 at 10:27:51 AM
Wall schedule - level field missing |
Fri, Mar 27, 2009 at 8:13:10 AM
Revit Revisions - Add field |
Tue, Jan 15, 2013 at 8:23:50 AM
11
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
