67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Text Issues
Mon, Mar 9, 2009 at 2:59:24 PM | Text Issues
davbrink
4 Stars: 1 Votes
OK I am getting really frustrated with Revit (2009).  I am transfering our sheet specs from AutoCAD over to the template file. I have four columns on my sheet that go from top to bottom. I understand that there is no formatting such you have with MText. I can live with the text being about 5 version back of AutoCAD. I can live with the hard tabs to get index formatting.  But what is driving me nuts is the text going out side of the text box. I go and stretch the text box so they are not overlapping and then in jumps back in. I have no idea what causes it to creep out side of the box or how to get it back in.
If anyone has anything that can shed some light on this issue so that I don't scrap Revit alltogether and go back to a parrallel bar  and triangle.
Mon, Mar 9, 2009 at 3:04:12 PM | Text Issues
SRobbins1977
If you are importing from AutoCAD then in AutoCAD change your text to a True Type Font and do your formating in AutoCAD.  Then when you import to Revit, Revit shoudl reconize that text type as TTF nd keep formatting.  I hope this helps.
Mon, Mar 9, 2009 at 3:15:08 PM | Text Issues
davbrink
4 Stars: 1 Votes
I actually copied the everything from AutoCAD into a WORD document and copy clipped the text into a text box in Revit. So everything is already True Type Font.  Like I said I can work with the formatting limitations it is the jumping back and forth of the text box that is driving me nuts.
Text Visibility
Tue, Sep 12, 2017 at 7:19:11 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:16 PM
Text issues with generic annotation family nested into detail component.
Mon, May 19, 2014 at 11:27:44 AM
Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
Wed, Dec 29, 2010 at 5:27:09 PM
text box
Wed, Jan 7, 2009 at 4:47:43 PM
Page generation time: 0.8627
