Forums >> Revit Building >> Tips & Tricks >> What's Your Windows Screen Resolution????
Well this may be the simpliest tip but it never occurred to me until i was watching an AU screencast and saw all the drafting tools were available. I've been working at 1024x768 resolution for so long, but if you change it to 1152 x 864 and you have a limited amount of design tabs open.....you can say goodbye to "MORE TOOLS". It always bothered me that when detailing, the tools i was using the most were "hidden" Of course there are two issues here. 1. This will not be an issue with the Ribbon (...or maybe it will help with design real estate) 2. Everything is so small. What setting are you out there using? Let me know. John
I use 1280x1024...
Well, I use 1280 x 800.....
i use 1650 x1050 Laptop i use 2560 x1600 Desktop
Edited on: Sun, Mar 8, 2009 at 2:02:48 PM
Mouse Acceleration (resolution) disappears when I get into revit |
Fri, Feb 23, 2007 at 2:45:28 PM
Temp Dim's are too small |
Mon, Jul 30, 2007 at 10:36:05 PM
revit won't render in 3d |
Wed, May 29, 2013 at 4:40:54 AM
stair text too small |
Thu, Dec 8, 2005 at 10:39:27 PM
properties and project browser windows reset |
Thu, May 9, 2013 at 3:13:39 PM
Members: | 2098726 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
