54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> IES Photometric lighting issue - no light
Sat, Mar 7, 2009 at 3:42:51 PM | IES Photometric lighting issue - no light
rodells
Revit Architecture 2009, I am trying to use IES lighting.    I have set the light distribution to web in the family editor, and tryed various IES file for the Photometric Web File; renderings are black.    The light source is not above the ceiling or in a fixture where the light would be trapped.      Fixtures that render functioning with light using other light source definitions, i.e. spot, work fine, but when the same fixture uses an IES file, no light when rendered.
Mon, Mar 9, 2009 at 7:32:27 PM | IES Photometric lighting issue - no light
iREV
3.5 Stars: 3 Votes
I am currently using Revit MEP '09.  When creating the perspective go to view properties and make sure that the discipline is set to Architecture. Cryingthis may only be a MEP option).  Next, check the to see if the artificial lights are on under the lighting area in the Rendering pop up window. Also, in this area make sure under Scheme that you have selected either interior or exterior artificial lighting is on.
Mon, Apr 27, 2009 at 8:41:37 AM | IES Photometric lighting issue - no light
robert
hi.
what is a IES file?
robert
Mon, Apr 27, 2009 at 8:46:33 AM | IES Photometric lighting issue - no light
robert
an other question:
i have told revit building lights do not work in mep and vice versa
what is this alll about ?
Mon, Apr 27, 2009 at 9:28:24 AM | IES Photometric lighting issue - no light
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
an ies file is the photometric information of a specific lighting fixture including things like balast, lumens, etc.., it is basically a test file that the manufacturer provides, this is not to be confused with the other ies (integrated environmental solutions) <ve>.
 There is no problem going between the platforms in mep 08 there was the option to associate an ies file and not in arch, in 09 autodesk gave the architects the power to do this too. i mainly use mep, so we use the ies files for lighting analysis even though it is giving us only zonal cavity calculations we still export to ies <ve> to do the point by point calcs. hth robert
 irev your analysis of the problem is correct and should work.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Thu, Aug 13, 2009 at 3:30:29 PM | IES Photometric lighting issue - no light
JEH01
Y'all have no idea how long i have been trying to figure that one out.... Never thought to switch disciplines. Now i can proceed to the next emarassing failure.
Thanks
IES FILE AND LITGHT SOURCE NOT IN SAME DIRECTION
Mon, Feb 6, 2017 at 2:16:46 PM
.ies file orientated wrong for tube light source
Mon, Nov 17, 2008 at 2:00:27 PM
lighting analyse with IES
Mon, Apr 28, 2008 at 1:56:57 AM
IES files in Revit
Mon, Feb 6, 2017 at 4:00:15 PM
Aligning IES with light fixture
Fri, Sep 12, 2014 at 10:18:00 AM
Page generation time: 2.5276
