75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to merge Generic model with wall
Sat, Mar 7, 2009 at 5:22:22 AM | How to merge Generic model with wall
push84
Hi, I created band using generic model (refer images) now i need this to merge with wall, i need the same hatch pattern and it should be able to do join geometry. Any idea how to achieve this?
Thank you in advance
push
Edited on: Sat, Mar 7, 2009 at 5:23:44 AM
Sat, Mar 7, 2009 at 6:10:04 AM | How to merge Generic model with wall
tim123
4 Stars: 19 Votes
Go into edit mode of you element.  You should then be able to add materials.  I would create this in the walls category rather than generic model but you should still be able to join the geometry.
Sun, Mar 8, 2009 at 11:27:55 PM | How to merge Generic model with wall
push84
hi,       i removed that wall based family and created additional wall and sketched it to bring my band. But it would be better if we can add hatch material to the wall based family. Before i created materials inside the family and applied material inside project but the material did not assigned to it.any ways i solved my problemThank youpush
Can you Merge Walls? [ 1 2 ]
Thu, Jul 25, 2013 at 3:07:26 PM
17
Generic Model - Wall Based - Model wont align to different Wall Thicknesses
Sun, Jul 10, 2011 at 6:23:24 PM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:19 PM
How to place a camera to merge a picture with the building model?
Fri, Nov 4, 2005 at 10:45:57 AM
Generic Model Materials
Wed, May 18, 2005 at 5:03:39 PM
Page generation time: 1.2655
