68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problem with site shading with edges
Fri, Mar 6, 2009 at 10:02:53 AM | Problem with site shading with edges
dauten
Hello:  I'm using RAC 2009.  I have imported a site dwg from my surveyor, and have created a toposurface with it.  Now I'm trying to apply shading or shading with edges via "View" settings to present some initial 3D's to a client, and all I get is wire frame for the site (the building is fine).  When I went back to the original dwg to associate it with materials, I must have done something wrong - I'm not at all familiar with Autocad, which is probably why that's not working.  Is there any way to make shading work within Revit?  It's a complex mountain site - do I have to enter each point by hand to make it work?  Or do I have to try to learn how to do something to the site in its dwg form in Autocad?  Any help or suggestions appreciated!
 Thanks, Deb
Fri, Mar 6, 2009 at 10:06:38 AM | Problem with site shading with edges
Read your H E L P
Use site as your search then read: Creating a Toposurface from Imported 3D Data
Fri, Mar 6, 2009 at 3:17:35 PM | Problem with site shading with edges
tim123
4 Stars: 19 Votes
You say that you have created the toposurface from the cad drawing.  You don't need any information from the cad drawing other than the heights.  You should be able to set the materials for the toposurface in the element properties in Revit.  Attach the cad drawing and we can check to see if it works.
Sun, Mar 8, 2009 at 3:59:33 PM | Problem with site shading with edges
dauten
Thanks to all.  I was able to recreate the toposurface and make it work.  I thought I'd done it exactly this way before, but apparently didn't.  Anyway it works now, and thanks to all for their time.
shading with edges problem
Wed, Nov 17, 2010 at 6:49:50 AM
Problems plotting "shading with edges"..................
Mon, Mar 24, 2008 at 8:01:10 AM
Shading with edges in plan
Mon, Sep 8, 2008 at 4:18:15 AM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:20 PM
11
Shading w/ Edges Color Differences
Thu, Jul 23, 2009 at 2:18:44 PM
Page generation time: 0.8452
