82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window family
Fri, Mar 6, 2009 at 6:04:29 AM | Window family
nirim
5 Stars: 12 Votes
Hi there
 I wented to build  new window family, I start the window from existing one, during the process I notices a strange element within the window, it is element named by Revit: Frame/mullion: Joined Geometry. You can’t edit that element and it appear to be under the real elements that build the window,  if you delete the object it seems that most of the constrain remove as well. What is that object? And what is it good for?
Nirim
Fri, Apr 24, 2009 at 6:47:19 AM | Window family
nirim
5 Stars: 12 Votes
Any one?
Fri, Apr 24, 2009 at 7:09:56 AM | Window family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you use the join geometry tool, revit basically creates a new compiled object that is made up of the various individual pieces (helpful when wanting to hide things or know if joined geometry exists).  You can select it, but you can't really edit it as such.  In order to edit it you need to use your tab key to select the individual extrusions, sweeps, blends etc that make up the joined geometry.
HTH.
Regards,
Chris.
Fri, Apr 24, 2009 at 11:23:41 AM | Window family
nirim
5 Stars: 12 Votes
Thanks for that Mr Spot
nirim
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
Imported family not flexing in window family
Thu, Jan 31, 2013 at 7:21:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:11 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:53 PM
Page generation time: 6.4976
