69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curtain door
Thu, Mar 5, 2009 at 8:17:34 PM | Curtain door
Hi
 I have a problem regard with the curtain dooor I have followed some of the ideas given in this site but only i dea works was about the editing of curtain wall to represent as curtain door but the problem was how can i attach a curtain door to a curtain wall please help
thanks and best regards to all
Fri, Mar 6, 2009 at 4:05:05 AM | Curtain door
4 Stars: 203 Votes
If you check your HELP menu you can see that but go with your mouse into a panel of the curtain wall, then with the TAB key click until you have highlight that panel, then pick in that, go to the Options bar and in the properties you can select the curtain door you want, don't forget to load into the project the curtain doors you want before...
Sat, Mar 7, 2009 at 1:27:20 AM | Curtain door
 Thanks for the great reply i will try that hopefully works fine
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:11 PM
curtain wall door
Tue, Jan 31, 2006 at 1:36:59 AM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:34 AM
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:09 PM
Page generation time: 3.1187
