35 Users Online (33 Members):
Forums >> Workflow & Implementation >> Worksets >> Editing elements of locked worksets
3 Posts No Rating |
Hi all, i'm working on a solo projects. i created a central file and i added my objects to worksets. i rendered some worksets as (Non Editable) yet still elements included in them can still be moved and deleted and edited in all sorts of ways! am i missing out on something here?? why are elemts still editable though the workset is locked?? please advice.. thanks
This seems to be a common misconseption for my students. If your workset is set as "Non Editable" it means that everyone has access to them and can change them. If you go in and make you the owner of the worksets it will make them "Editable" where it will just show the name of the current workset. When you own a workset nobody can do anything with this. So making it non editable does not lock your workset, making someone the owner does.
3 Posts No Rating |
Ok so making a workset Non Editable has no effect of any kind?? please correct me if i am wrong. Now i'm working on a solo project so i own all the worksets..is there no way around that?? i just need my elements to be locked while i'm working to avoid mistakes. thanks a lot !
theorical working as a single user you would not need worksets. they are designed to be used in a multi-user setup. but alot of people like to used worksets as a replacement for layers so they can control functional areas of a project. you could try working under mutiple users name to acheive your goal.
Edited on: Sat, Mar 7, 2009 at 10:41:04 AM
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP |
Tue, Oct 23, 2007 at 2:36:13 PM
Wed, Feb 1, 2012 at 5:04:15 PM
Worksets in structural projects |
Mon, Jan 9, 2017 at 5:53:42 AM
Cant Delete one of My worksets...please help |
Thu, Feb 14, 2019 at 1:48:12 PM
13
linked file elements on host workset...help |
Fri, May 4, 2012 at 5:46:58 AM
Members: | 2056530 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
