81 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> curved curtain wall
Wed, Jun 22, 2005 at 2:00:24 PM | curved curtain wall
rubiks cube
Hello when I make a curved curtain wall of 180 degrees, and add mullions, I find that the end mullions do not line up to 180 degrees How do i make them do this cc
Thu, Jun 23, 2005 at 2:15:34 AM | RE: curved curtain wall
eldados
eldados Avatar
4.5 Stars: 8 Votes
that is because the curtain wall is not perpendicular to the 180d line,which is wierd... try and create a curtain grid as close as you can to the edge, not perfect but close Smile Post edited on 2005-06-23 02:18:25
Thu, Jun 23, 2005 at 9:23:12 AM | RE: curved curtain wall
vdogg
It may also be because the mullions are placed on the grid at their centerline. Another way to correct this would be to create a new mullion type and have it place the mullion by the edge, not the center. Vanessa
Thu, Jun 23, 2005 at 7:28:18 PM | RE: curved curtain wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Actually, Just to clarify, edge mullions (mullions to the exterior edges of the wall) are placed by the exterior side so as not to modify the size of your wall. This is why your experiencing the problem. The other mullions in between this are placed at there centrelines. Solution would be to break the 180� into segments that allow you to have your mullions in the correct places...
curved angled curtain walling
Wed, Mar 8, 2006 at 4:18:51 AM
curved curtain wall, straight transoms, curved panels
Tue, May 12, 2015 at 8:36:04 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:48 PM
curved curtain wall
Sun, May 12, 2013 at 1:54:02 PM
curtain walls
Sun, Dec 7, 2014 at 9:29:55 PM
Page generation time: 0.9682
