Forums >> Revit Building >> Technical Support >> Glass Railings?
8 Posts No Rating |
I am fairly new to Revit. I am working in Revit 2009. I would like to create a floating staircase with the use of glass railings in a commercial setting. Ideally, what I would like is the omition of posts so that when you look at the staircase all you see are the stairs, the railing and bolts that connect the glass to the stairs. I have put in my stairs but can't figure out the railing. I know that you can put in glass panels as balusters, but I don't know how. Please help! I have spent a lot of time trying to find other forums with this answer but am left frustrated. Step by step answers are apreciated greatly.
If you don't want posts you can create the glass panels as railings. Create a new profile about 20mm thick and 1000mm high. I assume your stair has structural glass sides. You can create a profile if required to support the glass. I'm not sure how the bolts would fix this down, but you could probably create these as balusters.
this will help you http://revit-alize.blogspot.com/2005/11/stairway-to-heaven.html
8 Posts No Rating |
Beautiful! Thanks so much!
Although an all glass railing is not included, everyone should open the rvt railing file in the on-line library. This is a great resouce ... just copy - paste into your model to get a railing that is close to what you want - then modify it.
http://revit.autodesk.com/library/html/
Staircase and glass railings |
Fri, Sep 6, 2013 at 7:51:06 AM
stair railings-inserting glass |
Mon, Dec 9, 2013 at 11:37:41 AM
GLASS RAILINGS |
Fri, Apr 3, 2009 at 3:22:30 PM
Railings / Glass |
Mon, Jul 23, 2007 at 10:38:57 AM
Creating a glass stair |
Tue, Oct 25, 2016 at 10:39:30 PM
Members: | 2098828 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
