Forums >> Revit Building >> Technical Support >> Fascia Gutter Miter
![notagain Avatar](user_avatar/36981.jpg)
![4 Stars: 1 Votes](/images/stars_4.gif) |
anyway to miter these two...one is a fascia...the other a gutter
Edited on: Wed, Mar 4, 2009 at 12:51:43 PM
I really want this to work...some good things some bad |
Why don't you create that only with Gutter OR only with Fascia???
Your looking at one roof sloping with a cut out....gutter function won't work on fascia side...keeps crapping out...
Edited on: Wed, Mar 4, 2009 at 1:06:54 PM
Well, use the "wall sweep" with that profile...
thanks for suggestion...no go...I need the gutter to follow the slope...1/2" = 1'
Edited on: Wed, Mar 4, 2009 at 1:46:28 PM
![4 Stars: 19 Votes](/images/stars_4.gif) |
Add the sweeps in one go and they should mitre.
Tim, I knew the sweeps would miter...but how do get them to follow the slope of the wall/roof....I am working in 2008 and still no go...
got it....the fascia command will let wrap around and miter...thanks for all you help....
I don't have 2008, but what I did was use the fascia function with a gutter profile as the gutters do not attach to the sloping roof.
RAC09 - Roof Fascia Corner Miter on Square Cut |
Wed, May 27, 2009 at 6:57:00 PM
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
where is fascia miter? |
Thu, Sep 15, 2005 at 10:52:36 PM
Need Help With Soffit, Fascia, Gutter |
Fri, Dec 5, 2014 at 11:09:19 AM
gutter-fascia/flashing connection |
Wed, Sep 11, 2013 at 2:17:30 AM
Members: | 2019206 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
