Forums >> Revit Building >> Technical Support >> walkthrough rendering frame counter?
1 Posts No Rating |
can anyone help us get rid of the frame counter appearing in the rendered walkthrough AVI playback in Revit Building 09? Can't find any reference to it in Help or dialogues.Thanks
from what has been said by other users, the only is to use a third-party video editing package to remove the counter
24 Posts No Rating |
What third party software are you reffering to?
14 Posts No Rating |
I use on called VirtualDub...it is simple but free. There are other paided ones my office uses primarily Adobe Premiere but it is much more complicated. None of us understand why they have the counter...if someone could enlighten me I would appreciate it. The only reason I could think of is to get be able to splice together films if you are poor man server farm rendering.
I believed this was mentioned before that in 2010 version the frame counter is an option now...you can turn it off if you want to. But i'm also using 2009 and the way i fix it is by using VirtualDub or Camtasia Studio.
"If you tell the truth, you don't have to remember anything" |
Where would you go to turn it off?
I'm assuming when you export the walkthru to an avi or images files. I don't have 2010 so i can't tell for sure.
Walkthrough rendering stops [ 1 2 ] |
Mon, Feb 22, 2010 at 4:30:52 AM
17
can you render a walkthrough in Revit Architecture 2009..??? |
Tue, Jun 4, 2013 at 4:15:54 PM
11
Walkthrough Export is very slow |
Fri, Feb 13, 2009 at 2:44:47 PM
Walkthrough |
Thu, Sep 24, 2009 at 8:24:32 AM
Exporting Walkthrough Trouble |
Thu, Apr 17, 2008 at 8:00:51 AM
Members: | 2102478 | Objects: | 23173 | Forum Posts: | 152290 | Job Listings: | 3 |
