123 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Bringing ADT lines into a Revit Model
Tue, Mar 3, 2009 at 4:14:47 PM | Bringing ADT lines into a Revit Model
Kirkeron
I'm having difficulty either dragging and dropping an ADT line dwg. into Revit or linking it into that view only, when I try both nothing shows up?  I've checked Visibility Graphics and I now have about 8 imported files (same file) but nothing showing up?  I exploded in ADT before importing and put all on the same layer but no luck.  Can anyone direct me how to both remove all my similar import files and get one of them to appear?
Thanks for any help you can provide...
Wed, Mar 4, 2009 at 6:56:22 AM | Bringing ADT lines into a Revit Model
Two things may be happening ..
the most likely is that the CAD drawings origin is well away from the drawing - when importing, use the manually place / cursur at center and see if that helps.
the other issue is scale - so you may have to look at that.
Bringing Sletchup models in to revit
Thu, Jan 29, 2009 at 1:10:26 PM
REVIT X ADT
Sun, Jan 8, 2006 at 10:40:42 PM
ADT VERSUS REVIT
Tue, May 15, 2007 at 2:07:40 PM
12
Converting Room Areas to Walls and Importing ADT lines into Walls
Mon, Sep 15, 2008 at 12:44:51 PM
ADT to revit upgrade
Fri, Jun 2, 2006 at 1:38:23 AM
Page generation time: 9.8956
