60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Editing System Families
Tue, Mar 3, 2009 at 11:38:49 AM | Editing System Families
IloveSKETCHUP
I have a system family which appears to be made up of multiple families in my model on a ramp.
Element Properties: System Family: Railing
Is there any way to find the .rfa and edit it? Where is it located? Can I edit a family within the system family?
I just want to change the bracket length and tube size and then load into project. These are NOT option in the properties.
Any help would be appreciated.
Thanks!
Tue, Mar 3, 2009 at 11:52:53 AM | Editing System Families
KingRevit
4 Stars: 12 Votes
inside the railing properties go to the balasters and find out whart type it is, then browse through the famlies in the project browser and the edit it
Sat, Dec 5, 2009 at 3:53:11 PM | Editing System Families
fallingdog
I have edited may system families with this method and it has worked fine.  However I would like to know if there is a way to change the "sub families" that the system families are using.  for example in the section system family I can duplicate, rename, and edit the sub family (i.e. section tail - filled) but I can not tell the system family to use the new family that I have made.  This means that I have to change the original families.  Is there a way to do this?  Is it possible to make a new system family?
Edited on: Sat, Dec 5, 2009 at 4:39:49 PM
Editing system families dimensions
Mon, Nov 9, 2009 at 7:10:39 AM
Editing Families
Fri, Oct 8, 2010 at 12:02:04 AM
DETAIL BUBBLE - editing system families
Tue, Feb 2, 2010 at 7:08:11 PM
Help editing All in one Revit Content families
Mon, Dec 21, 2015 at 1:27:26 PM
editing families when creating new
Fri, Sep 9, 2005 at 3:17:21 PM
Page generation time: 0.5555
