59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Tracing filled regions with linework
51 Posts No Rating |
Can anyone give me ANY GOOD REASON WHATSOEVER for drawing a filled region with invisible lines, finishing the sketch, and then tracing the filled region boundary with detail lines? I know that way back in the early days, if a filled region was exported to DWG, the filled regions came out black. Doing filled regions as I described above allowed the user to open the DWG and delete the black areas, leaving the detail lines. Now that we are many releases past this, I cannot hink of a single reason to not use linetypes in the filled region sketch, and let it go. ANY possible ideas? Maybe because it is quicker to change the lineweight of a single line because you do not have to enter the sketch???
Filled Regions |
Thu, Jul 19, 2007 at 2:42:06 PM
revit plotting to pdf |
Tue, Aug 13, 2013 at 9:17:49 AM
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation |
Wed, May 25, 2005 at 1:35:38 PM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
