117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Clerestory windows in plan regions
Mon, Mar 2, 2009 at 8:58:57 PM | Clerestory windows in plan regions
aheimburger
I have a bunch of clerestory windows that I've gotten to show up using the plan regions but none of the detailing shows up, they are just blank white boxes in the wall.  any suggestions?
Tue, Mar 3, 2009 at 6:53:15 AM | Clerestory windows in plan regions
3.5 Stars: 395 Votes
You have not given us enough information to help you.  You say you see the windows so what's missing?
Tue, Mar 3, 2009 at 11:29:09 AM | Clerestory windows in plan regions
aheimburger
Sorry.
 the 'rough opening' of the window shows up, however none of the detailing (i.e. window frame, glazing, etc.) shows up.  I put one of the walls in question into a blank file for you to look at.  One of the windows now has deatailing and two still don't.  it is probably a simple stting issue, but I've played with it a good bit and can't get it to work right.
Tue, Mar 3, 2009 at 11:55:50 AM | Clerestory windows in plan regions
KingRevit
4 Stars: 12 Votes
its your visibility settings in your window family
clerestory
Fri, May 20, 2011 at 8:17:17 AM
Displaying windows above cut plane
Mon, Oct 27, 2014 at 2:39:24 AM
Plan Region nesting problem
Mon, May 18, 2015 at 6:04:23 PM
Plan Region Layout
Fri, Jan 25, 2008 at 7:16:06 PM
Clerestory Walls
Wed, May 17, 2006 at 1:54:51 PM
Page generation time: 0.9957
