99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> Inconsistent Pi
![notagain Avatar](user_avatar/36981.jpg)
![4 Stars: 1 Votes](/images/stars_4.gif) |
Well trying to get circumference of a circle...pretty easy stuff...I keep getting inconsistent units.... 3.14 * diameter and I get that need a little help...
I really want this to work...some good things some bad |
![5 Stars: 3 Votes](/images/stars_5.gif) |
probably you don't have the "Type of parameter" correct !!!
Joao Cercas
On Revit 2010 (SP3) |
it's length time number....should it be length times length
got it....I played with the parameters....don't understand syntax yet...getting there...thanks for helping meEdited on: Fri, Feb 27, 2009 at 12:40:08 PM
Edited on: Fri, Feb 27, 2009 at 12:40:22 PM
![4 Stars: 19 Votes](/images/stars_4.gif) |
Have you set the circumference as a Length? It should work.
The Bane of Formulas - Inconsistent Units |
Wed, Jul 2, 2014 at 4:39:36 PM
Inconsistent units |
Wed, Aug 11, 2010 at 8:17:26 AM
Inconsistent units workaround |
Wed, Jun 22, 2005 at 7:52:54 AM
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
Inconsistent data in DWF exports |
Fri, Nov 20, 2009 at 7:13:48 AM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
