61 Users Online (59 Members):
Forums >> Community >> Newbies >> Showing windows on the floor plan
12 Posts No Rating |
Hello, I am new in this forum and new to revit aswell. I have a problem with windows to show on a floor plan. I would like to know, how can I show my windows on a floor plan like shown on the attached file. This window is a Plain composite but I would like to use M_Fixed windows. And usually windows in the walls are grey when i use shading with edges.
You must put the image of your issue also, maybe you have the "Cut Plane" wrong or can be the "Visibility" of the family itself, could be several things....
Sorry, my mistake. One of the attached files is with M_Fixed (grey) window and the second is with Plain composite (white) window. Is it possible to make M_Fixed window to see on a floor plan white, when the shading with edges is on, like second one?
Edited on: Fri, Feb 27, 2009 at 3:21:26 PM
In that plan view did you check the "Cut Plane"????
Thank you for your help. I managed to fix this problem by editing the specific family and changing the visibility. Now I can see my windows in white color on my floor plan to separate them better from the wall.
Window from floor above showing on ground floor plan |
Mon, Oct 10, 2016 at 7:13:10 AM
Windows not showing correctly in legend |
Mon, Dec 14, 2009 at 5:22:42 PM
Ceiling Model Lines Showing up on Floor Plan |
Tue, Dec 13, 2011 at 6:04:04 AM
Walls not showing in plan region |
Mon, Feb 18, 2008 at 1:59:12 PM
14
Light switches not showing on floor plan |
Fri, Apr 29, 2011 at 2:14:19 PM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
