72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> ACAD Import
Fri, Feb 27, 2009 at 11:05:08 AM | ACAD Import
brandycat
I am trying to import an AutoCAD background into Revit and I keep getting a pop up that says "can't import file".  I have tried various things.  I am wondering what else I may try in order to get the file into Revit if possible.  Please help.
Fri, Feb 27, 2009 at 11:18:09 AM | ACAD Import
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You've got to love the helpful error msgs that Revit gives you.
Are you on the latest service pack for Revit?
What version of ACAD?
Usually it's a issue with the CAD file and not Revit.
Did you audit the CAD file, clean it up, wblock it...typical things to do to help.
You might also check the scale list and clean it up...that might be the first thing I look at actually.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Feb 27, 2009 at 11:33:12 AM | ACAD Import
brandycat
I tried making a Wblock, I tried making a new file, and I've tried scaling.  We are using AutoCAD 2009 and Revit Architecture 2009.  Any other ideas.
Fri, Feb 27, 2009 at 12:17:49 PM | ACAD Import
brettgoodchild
4 Stars: 17 Votes
Clean out the scale list.
There is a utility from the factory out there to do this automatically...or you can do it manually I suppose.
Other than that I'm not sure. Most of the import issues were taken care of so I'm not really sure what it could be.
                             ~ Abraham Lincoln
Fri, Feb 27, 2009 at 12:23:46 PM | ACAD Import
brandycat
Thanks a lot!
Fri, Mar 13, 2009 at 5:21:29 AM | ACAD Import
FJ22
Is the problem solved yet? If not , this might be a simple clue. But it's not that you are in the drawing in ACAD when you try to import it into Revit? This may cause problems as well.
Wed, Apr 1, 2009 at 9:04:59 PM | ACAD Import
Dasher
Are you trying to Import from Paperspace or Model space?
Use model space
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:46 AM
Fatal Error when linking/importing ACAD files
Fri, Aug 15, 2008 at 12:43:27 PM
import acad 3d objects and convert to Revit
Tue, May 24, 2005 at 8:48:46 PM
linking from acad
Sun, May 15, 2005 at 12:43:42 PM
ACAD Import issues
Fri, Dec 23, 2005 at 11:45:46 AM
Page generation time: 0.4092
