Forums >> Revit Building >> Technical Support >> Help!!!!! Families not everwriting
Thu, Feb 26, 2009 at 8:20:29 AM | Help!!!!! Families not everwriting
jreding
jreding Avatar
For some strange reason my families are not overwriting. For instance I have a column if I change something in it and try to reload it, it will not change the previous families in the project although I tell it to overwrite the exisiting families. If I resave the family with a new name, then I can use that modified family. But exisiting components will not change appearence. I need to delete the family and put the new one.
Any suggestions?
Edited on: Thu, Feb 26, 2009 at 9:01:53 AM
Thu, Feb 26, 2009 at 10:11:37 AM | Help!!!!! Families not everwriting
KingRevit
4 Stars: 12 Votes
are you ticking the little box when you relaoad it to overwite the paramaters? are the paramerts instance or type?
Thu, Feb 26, 2009 at 3:42:38 PM | Help!!!!! Families not everwriting
shaun_kiwi
5 Stars: 2 Votes
When geometry has a parameter attached to it say a dimension or a material, it becomes a property of the component it project space. If you adjust this parameter while editing it in the family, adjusting width in family types and reload it it stays as it was in the project. But if you select the dimension and add a NEW parameter naming it something slightly different and giving it say the same formula as the old one so that it performs the same and for materials adding a new parameter and also adding a new material. When reloading it all will instances change in the project. Renaming the parameter isn't enough to make the changes either. The project just reads it as a name change.
Shaun
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Rendering Families in Revit 2010
Mon, Jul 19, 2010 at 5:39:45 AM
Page generation time: 0.5528
