95 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 3D view visibility error
Thu, Feb 26, 2009 at 3:52:02 AM | 3D view visibility error
Rams
3 Stars: 3 Votes
Can someone tell me the reason for the visibility error in 3D view?
See attached snapshot for more details.I have tried all four option - Wireframe, hidded line, shading & shading with edges. Also i dont think its a grahic card issue because rest all the files are OK.
 Please give me some suggestions.
Now on the implementation stage....
Thu, Feb 26, 2009 at 3:57:29 AM | 3D view visibility error
cercas
5 Stars: 3 Votes
Probably if you install the latest service pack for revit that problem will disappear..
 Someone said that if you chose the home of the viewcube, that will correct the view.
If not, if you erase 3d view, and create a new one, that will solve the problem...
Joao Cercas
On Revit 2010 (SP3)
Thu, Feb 26, 2009 at 4:05:32 AM | 3D view visibility error
4 Stars: 202 Votes
Rams, did you search here for this kind of issue???? because yesterday i awnser one similiar question and i remember there are much more in the forum, try this, in the top menu you have the 3D icon (Blue House) click on it if don't work delete the 3d view and create a new one... by the way, what is your graphic card???
Thu, Feb 26, 2009 at 4:40:38 AM | 3D view visibility error
Rams
3 Stars: 3 Votes
Deleteing the 3d view solve the problem.
Thanks both of you. But any idea - whar can be the reason for this problem?
Cheers
Cut a wall along a other wall
Fri, Sep 16, 2011 at 3:28:08 AM
Reference plane visibility in section
Mon, Aug 27, 2018 at 7:11:51 AM
visibility issue with view and view on sheet 2017
Wed, Jul 19, 2017 at 11:47:37 PM
Visibility Error
Wed, Apr 30, 2008 at 11:35:43 AM
A serious error has occurred. It is strongly recommended that you use Save As to
Fri, Oct 3, 2008 at 7:52:59 AM
Page generation time: 2.4978
