79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Dimensioning Drafting Views
![4.5 Stars: 3 Votes](/images/stars_4.5.gif) |
I still use Autocad on some sections, etc. My problem is when I reload I lose the dimensions even though that dimensioned object might not have changed (the .dwg changed on another part). I dimension and annotate using Revit.
Link instead of inserting the cad drawing.
Tried that, no luck. It does this 99 % of the time...Occasionally, the dimensions will stay. Can't figure out the patten.
![coreed Avatar](user_avatar/14568.jpg)
try creating a workset just for the section link and import the section link into the workset. that should solve your problem of losing dimemsions when reloading.
8 Posts No Rating |
coreed.. i tried to do what you suggested but i am still having problem..i link the cad drawing to drafting view with craeting a different workset.. but whenever i reload same cad file, some of my dimension erased eventough any changed made related objects.. i dont know why some stay some erased.. any suggestion??
As a quick solution. I drew thin lines where I wanted to locate dims..then dimensioned to them so the dim was associated to the line not the imported dwg. If I had to reload I could then just move the lin(s) as needed. Wasn't so bad. One thing, if you've already dimensioned and added to the dim. text string (ie: Head Ht. = blah blah) and then you re-associate to the lines after the fact you will lose this info and have just the dim text only so put the lines in at the beginning.
8 Posts No Rating |
it is a solution but wondering if there is easy way to do it with out drawing reference lines for dimension.. I am sure there must be a diffrerent and easy way. i posted these questin at chatting linh, but could not get a proper answers..
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
Converting Model Views to Drafting Views |
Fri, May 13, 2016 at 2:13:29 PM
Save a sheet of drafting views |
Wed, Mar 1, 2017 at 5:34:28 PM
DRAFTING VIEWS ON MORE THAN ONE SHEET (REVIT 2012) |
Wed, May 23, 2012 at 8:42:46 AM
DRAFTING VIEWS |
Fri, Oct 13, 2006 at 3:34:29 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
